Shows the results of executing default.xsf on bootup.
N/A.
Use this command to show results when a default.xsf file is loaded.
An existing default.xsf file is executed if the switch comes up in an unconfigured state because the configuration file is missing, or the configuration file cannot be determined due to a corrupt NVRAM or other problems. This returns the switch to some basic configuration. When default.xsf is executed, the show switch command shows default.xsf as the booted configuration file.
This command shows the results of executing the autoexec script:
show script output default
When there is no default.xsf file, there is no response.
